Old 01-25-2023, 11:17 AM
farmer52 farmer52 is offline
Default Manual hydro relief valves
I plan to remove the valves and send them to MachTech for rebuild. Can the tractor be pushed with the valves removed? Will oil shoot out? I do not plan to run the engine, just push. Thanks!
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 01-25-2023, 04:57 PM
Good question. I would think not. In order for oil to shoot out, the Charge Pump would have to rotate.
Old 01-25-2023, 05:34 PM
Ambush Ambush is offline
No oil should come out other than any drain back from the control valve. They are ported directly to the case but with only the motor rotating group turning it won't displace any oil. After draining oil from the hydrostat, I remove the valves and fill the pump/motor case through the release valve ports, just as a precaution. Doesn't take much once the hydro/diff is filled to capacity.
