HELP. ok i just rewired my 127 with new porch harness, hooked it all up. There is a "short" or something going on. Ok, when I hook the Gray wire up to the VR, (the one that goes to the dash gague, the VR starts Humming loud. I just also figured out that the Coil is bad, but would that cause this? Is the VR bad? I also have new points and condenser installed, Please Help !!!
Jay I had the same problem when I fried my harness (orginal not the porch) I had it wired up wrong. Make sure that the VR is wired up right. Make sure that you can read the VR where it's stamped on the leads. For my 122 the wiring diagram was labeled wrong.
Wiring Diagram http://www.onlycubcadets.net/forum/showthread.php?t=35 VR Diagram http://www.onlycubcadets.net/forum/showthread.php?t=2 When the VR is installed it should be Top F Middle GEN Bottom Bat Make sure that the Starter/Generator is hooked up per the wiring diagram. That's what I had to do to fix mine for my 122. They use the same VR and Starter/Generator. Hope this helps! |
Also, make sure you have the correct V/R. It might also be a good idea to take the cover off and make sure one of the contacts isn't stuck shut.
ok took cover off, it was all white corriosion, got it free and cleaned the points. left the cover off and as soon as i put the gray wire back on, the thing moved and there was a loud humm and was sparking by the points. discionnected right away!!!! what ya thik?
Is this how you have it wired up?
thanks, funny thing is, the way yours is wired, according to diagram is wrong.
How did you verify you had the correct wires going to the correct places? Can you post the wiring diagram you are using?
and http://www.cubfaq.com/wiringdiagrams/127.jpg different from your picture, the middle is the same but the 2 ends are reversed !!! |
I've looked at Methos's pictures and the two wiring diagrams, and EE I'm not, but the only conclusion I can reach is yours is wired wrong. His connections on the V/R and S/G match the two diagrams. YOU have two wires switched. His tractor is wired correctly per the wiring diagrams.
On the diagram the Gray is on top right, look at the picture, the same location the Yellow is on top. The VR is is the same orientation on the pic and diagram........... What Am I missing? On the pic the "bat" is Gray on bottom, its on the top in the diagram. So Now I am confused !!! |
| Thread Tools | |
| Display Modes | |
