Go Back   Only Cub Cadets > Resources > Technical Library - Tractors > Technical Tips
Closed Thread
Old 04-23-2011, 07:17 PM
Default Throttle Shaft Bushing Part Number for those that might need it.
I decided to remove the throttle shaft on my 128's carb and get it tightened up. I went to Ace Hardware who carries Hillman products and talked with the Hillman representative that works at that store. He told me they had the bushings but that they now carried them in Servalite brand name. Hillman bought out Servalite.
The bushing fits perfectly and you do not have to drill your carb body. It removed all looseness in the throttle shaft. Also adding that the butterfly screw size is: 3-48 x 7/32"
A 3-48 x 1/4" works fine.
The Servalite part number is: ST814-2
They were about .80/each
Size is 7/16"x1/4"x1/16"
Here is the bushing:
The first bushing in place to be seated:
I used two bushings and a 6mm socket to seat them. Very very easy to do.:
Hope this is of some help.
Old 04-23-2011, 09:42 PM
There is no old bushing. The carb body wears out after years of use around the throttle shaft causing it to wobble and become loose and normally making the engine surge or not run smooth. These fit right into the body with no modifications.
Old 04-24-2011, 07:38 PM
I was wondering of this info could be added to the tractor technical section?
Adding also that the butterfly screw size is: 3-48 x 7/32" A 1/4" works fine.
Old 11-12-2011, 08:27 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Yes they will work on the 30's.
They won't work on the Carter "N" on an Original.
The dimensions for the "N" throttle shaft bushing are
OD ~.400"
ID ~ .215"
Thickness ~ .100"
I'll go see if I can find a standard thrust washer to fit this
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-06-2013, 05:31 PM
steve59's Avatar
steve59 steve59 is offline
Is this the correct bushing from Fastenal?
http://www.fastenal.com/web/products...ex?sku=0435459
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 01-06-2013, 05:32 PM
That would be it.
Old 01-06-2013, 06:47 PM
Here is an alternative....
Old 04-17-2017, 08:56 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Thank you for this detailed information. It'll help me get the throttle shaft fixed on my 123!
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Closed Thread
