Recall that I've been chasing a hard-starting issue with my S10.....it had a hard time getting started- cranking fine- when cold, just the engine catching and going. It happened a lot when it was below freezing outside, and I remember chasing issues like water in the gas, bad sensors, etc. It went away but as of late no matter the weather it didn't want to crank, like it was electrical. I'd turn the key and the dash would barely light up, it'd crank over slowly, and finally catch, but stutter, stumble and usually stall.
![]() -Check the simple things first. I thought it may have been a fuel pump issue, but that wouldn't explain the slow crank/newer battery. It's gotta be something electrical. -Disconnect battery cables. Clean contacts with wire brush. Re install, tighten snugly but not red-faced-grunt. -Follow negative cable to actual ground on the engine block. Terminal on the end was rotating on the bolt. ![]() -Remove bolt, clean both contact patches (and bolt) with wire brush. Lots of grease/oil due to the fact that the cable attaches at the bottom of the front of the engine. Replace bolt, tighten like above. Two days later the engine cranks like a Farmall H converted to 12 volt, and it's been below freezing both days. Thanks for the indirect help with my issue guys. I hope that I got it licked.
Glad you got it fixed Dan. OCC has a lot of talent, as far as I'm concerned this is the best Cub site going. Happy Cubbing my friend.
Good job Daniel. Poor pos/neg issues show themselves in strange ways sometimes. Give yourself some credit because there could have been a lot of parts changing involved if you didn't start simple like you did.
Glad you found the problem. With the wide range of people here, there is
probably not too many mechanical problems that the collective knowledge here can't solve. Plus we could solve most of the country's problems too but they aren't asking us ![]()
![]() Quote:
Glad to hear you got it figured out! I used to have a 85 ford diesel pickup. If it got a little corrosion on the battery cable it wouldn't start.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Just imagine that fix would have cost you $1000+ at a repair shop.
So know you have $1000 to put into another Cub!. |
Glad you got it fixed, Daniel!
Thread Tools | |
Display Modes | |
