Old 02-25-2016, 08:45 PM
BucknastyMiniRod BucknastyMiniRod is offline
Default 1711 problems
Hello, new member here and first order i would like to thank yall for having me. Me and my 1711 need help! She goes through oil quick. Smokes pretty decent. Hard to start. Under the motor is wet with oil but no drips to the ground. Did a compression test but it was cold got 50 on one side 55 on the other. Tried to get it to start to warm it up and do the compression test right with it warm and smoke rolled from under the seat. Now I get a click every now and then when I turn the key and sometimes nothing at all. Eletrical is not my strong point. Picked her up for 500 bucks and got 2 years use out of her. 1250 hours on the clock. Really don't want to dump a ton of money in her. Just looking for some insight, I want to save her if I can on a budget, she's in nice shape other wise.
Old 02-25-2016, 09:12 PM
Dirty Steve's Avatar
Welcome to OCC. What engine in that machine? Onan?
Old 02-25-2016, 10:18 PM
aagitch's Avatar
aagitch aagitch is offline
The smoke under the seat is probably from the starter solenoid. Sounds like an overhaul or repower is in order if the compression fails test.
Adrian
2072 (789513)
Old 02-25-2016, 10:20 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
First off.... Welcome to OnlycubCadets! you won't find a better place to find information and help for your cub cadet.
Didn't the 1711 come powered by a 17HP Kohler 2-cyl ?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
aagitch's Avatar
Kohler KT17 series I or II if it's the original.
Adrian
2072 (789513)
Old 02-26-2016, 01:00 AM
It is a Kohler KT17 series 2. Would the solenoid cause the sometimes click sometimes nothing at all when I turn the key. What is the best way to test a solenoid on these?
Old 02-26-2016, 02:15 AM
aagitch's Avatar
I don't know about the sometimes clicking part, but I know the smoke had to come from the solenoid or maybe the battery? Someone with more electrical knowledge will help u determine the cause.
Adrian
2072 (789513)
Old 02-26-2016, 02:19 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Check the battery cable connections for corrosion. Make sure terminals, posts and cables are free of corrosion and that the connections are tight. Is the battery fully charged and able to hold the charge? Don't forget to check battery acid levels too.
Queen Of The Quietlines!
Old 02-26-2016, 02:20 AM
aagitch's Avatar
U could jumper the solenoid after you perform the above recommendation if it still doesn't engage the starter.
Adrian
2072 (789513)
Old 02-26-2016, 09:42 PM
bocephus1991's Avatar
I'd say your engine is worn out. That's why it's hard to start and going through oil like crazy. Your putting a lot of stress on the starting system by cranking on it for long periods of time and that's probably why it's smoking under the seat. Like others have said, time for a overhaul or repower. I wouldn't worry with a compression test.
Brian
