Old 10-05-2015, 01:37 PM
Gregory Gregory is offline
Default 129 which needs to be moved
I have a 129 which currently has been sitting in the back yard with a non running engine and I need to move it so as to add a new engine. The relief valves on the trans are stuck in the closed and I have plans to send these to be rebuilt.
My question is, if I remove these valves from the trans, can I safely roll the tractor to where I need it to go or am I stuck working on it where it is ?
Greg
Old 10-05-2015, 02:14 PM
If you pull the valves it should roll freely.
Old 10-05-2015, 04:09 PM
Be vary careful that you don't get any dirt into the hydro or you will have even bigger problems. Here is the contact info for the guy that I use to do my valves.
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
Old 10-05-2015, 04:26 PM
Thank you for the info. I assumed this would work but wanted to check so as not to have to replace a pump. Also, I'll block the valve opening with some rags. Good suggestion.
Sam Mac, is this the same person who advertises valve services on ebay ?
Old 10-05-2015, 04:45 PM
Yes. He has done a bunch for me.
Old 10-05-2015, 05:47 PM
Thanks for the confirmation. It sounds like you are a satisfied customer !
