Old 10-18-2015, 02:55 PM
sd38-2's Avatar
sd38-2 sd38-2 is offline
Default Clutch job on my 104
My throwout bearing on my 104 finally took a dirt nap. I already had a broken teaser spring so now I have the 104 apart. I am replacing the throwout bearing, teaser spring, truing up the pressure plates, new clutch disc, and I am going to machine a new driveshaft for it. I was thinking of using stainless steel for the driveshaft, any recomendations? And for the clutch disc should i use a stock fiber one or upgrade to the aluminium disc? Tractor is used for mowing and snowplowing. Where is a good place to buy the spiral pins? My local autoparts store and Ace hardware dont have them, just regular roll pins.
Heres a few pitcures of the 104, one of it from last winter and the other two are tearing it down to do the clutch. I took off the rear sheet metal and pressure washed all the crud off it yeasterday.
1968 Cub Cadet 104
Old 10-18-2015, 04:32 PM
IHinIN IHinIN is offline
For the driveshaft, I recommend you use 4140PHT as it is harder and tougher than stainless. The fiber clutch disc is best for a working tractor. The aluminum discs are meant for pullers. I get my spirol pins from the local hardware store. McMaster-Carr carries them.
Old 10-18-2015, 04:48 PM
I make driveshafts out of 4140 alloy steel. I can supply spirol pins too. I can also machine your clutch disks too.
Here's my parts for sale thread
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Jeff
Old 10-18-2015, 05:05 PM
twoton twoton is offline
sd38-02, Jeff does great work, sounds like a package deal on the machining and driveshaft! This is my parts list from my clutch rebuild;
http://www.onlycubcadets.net/forum/s...0&postcount=43
Have fun.
Old 10-18-2015, 10:18 PM
Have fun.
I can do a package deal
Old 10-19-2015, 11:28 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Replaced the stock clutch disc in my 100 with a Vogel MFG. "High Performance Stock Replacement Disc" and like how well it's wearing. It's very much a worker tractor.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 10-20-2015, 09:58 PM
sd38-2's Avatar
Thanks for the replies! I'll be buying a stock replacement disc. Jeff I sent you a PM.
1968 Cub Cadet 104
Old 10-20-2015, 10:09 PM
Replied and gave some pointers
Jeff
Old 11-05-2015, 08:27 PM
sd38-2's Avatar
Update, I put the 104 back together earlier this week and got it setup with snow blade for the winter. The new clutch and drivershaft are working good, I used the tractor to pull my lawn sweeper to pick up leaves yesterday. now to do a tune up.
1968 Cub Cadet 104
Old 11-06-2015, 08:44 PM
I bought the correct drive shaft pin replacement from a Case IH dealer, and after about 45 min of running it fell out. Put it back in, and it fell out again. Jeff in PA made me one with knurling in the center and (so far) no issues. I would buy from him again. Good products and reasonable prices.
