Old 02-23-2015, 07:09 PM
northernredneck's Avatar
northernredneck northernredneck is offline
Default How to get this pulley off?
I want to get the flywheel off but I first need to get the yellow pulley that attaches to the clutch driver off that is pictured before I can get to the threaded hole to pull the flywheel. How do I do this? I have already pulled the flywheel nut so.... I'm at a loss any help would be appreciated! Thanks in advance. Also where would be a good place to get a new pulley seeing as how that one is chipped?
Old 02-23-2015, 07:11 PM
cubby102's Avatar
cubby102 cubby102 is offline
I usualy use a rubber mallet and tap it side to side. Usualy comes off. Its chipped more then likely cuz someone pried on it or hit it
Old 02-23-2015, 07:38 PM
I agree with cubby102
If you have already taken the nut off, it should come loose.
Old 02-23-2015, 07:43 PM
Do you think that it may be reusable or not with that piece missing?
Old 02-23-2015, 07:54 PM
cubby102's Avatar
Ive used them like that but check it out make sure itd not cracked anywhere else. It is a possibilty for chunks to come flying off. Clean it up and inspect it
Old 02-23-2015, 08:34 PM
It's fine. Unless you are running a hydraulic unit with it.
If you replace it, box up that one and send it to me.... I'll use it. I'm not scared.
Old 02-23-2015, 09:39 PM
Well back to the how do I get it off? I'd put a puller on it with some heat and it should come off. Most of the time they stick on the dowel pin.
Old 02-23-2015, 10:18 PM
theres nothing preventing the flywheel from coming off with the pulley still on it. you can remove the nut and gently tap the flywheel with a hammer and the whole thing should come off as one.
Old 02-23-2015, 10:37 PM
bocephus1991's Avatar
Try putting some penetrating oil on it over night and try tapping with a rubber mallet, should come right off. As for the flywheel , I've never got one off by just tapping on it, your probably going to have to put a puller on it.
Brian
Old 02-24-2015, 09:54 AM
10-4 on the pulley for the flywheel.
The drive cup is aluminum and it's corroded some and stuck tight to the F/W and crank. Knock it to and fro some, lightly, with a rubber mallet as suggested. Once you see it move a little it will only take a little more tapping back and forth and it will come straight off. You do have the nut & washer on the end of the crank off, correct??
Just don't try and turn it as it is held in place with a pin
Reinstall the nut flush with the end of the crank before you install the puller to avoid screwing up the threads. It will come off with a bang! and this also keeps it from flying off and possibly mashing a finger or a toe or breaking the fins if it were to land on the floor. A steering wheel puller is ideal but you could make your own if need be.
