Old 11-10-2014, 03:32 PM
steved steved is offline
Default PTO to Tiller Belt
I was researching the pto to tiller belt for my 105 and liked to fell out when I saw what Cub Cadet wanted. $100.00. Do you have any suggestions for a source without sacrificing quality? I've replaced the belts on my non cub ZTR before with hardware store belts and with OEM belts. Huge difference in quality. Is that the case here also? Thanks.
Old 11-10-2014, 04:07 PM
Get ready..... this is a big debate on here.
This is all I will say. I use Gates belts. Have one on my tiller drive. Paid around $65 for it. Will other belts besides CC ones work.... sure. Do they last? Sadly no. If you try any other belt other than the OEM one, I suggest a Gates. Otherwise, CC only. Yep, they're expensive. But it will last YEARS. Broken down by year, it's not really that expensive. Suck it up and get ready to drop some cash. No matter what, a GOOD belt that size is gonna cost $$$.
Rmowl's Avatar
Rmowl Rmowl is offline
Same thing happened to me when pricing the tiller belt. Check out vbelts4less.com I got mine think was around 150" for about $30 shipped, and have been very happy with it's operation. I have taken it to buddies gardens with rocky soil and performs flawless
-Rick
IH 782
IH 126
CCC 1863
Old 11-10-2014, 08:35 PM
kostendorf's Avatar
I got lucky, Seems I have the right combination a 1650 with a #1 tiller. Mine takes a IH-62235-C1: BELT-V 13/32 X 53" $26.77 and IH-61959-C1: V-BELT 7/16 X 145" $44.40
Old 11-10-2014, 08:42 PM
kostendorf's Avatar
The main problem with cheap belts is keeping them tight and in line. They are softer and stretch more. and good luck finding 7/16 and 13/32 wide belts.
Old 11-10-2014, 08:46 PM
On my 125 with a 1A tiller, the long belt is AX-144 and the short belt is 3Vx530 , both purchased at NAPA.
I have four seasons on those NAPA belts and they are holding up well. Plenty of rocks dug up too.
Old 11-10-2014, 09:02 PM
kostendorf's Avatar
I'm glad that 3Vx530 works for you. I tried one and it kept twisting. that's a 1/2" belt with the wrong angle on it. supposed to be IH-62235-C1: BELT-V 13/32 X 53"
Old 11-11-2014, 07:07 AM
Thanks guys, I appreciate all the input!
Old 11-11-2014, 07:44 AM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
You could probably do better than $100 for the OEM belt. I bought one for the wide frame for $85.00 from Marlin at Cub Cadet Warehouse. I believe he has the one for the narrow frame too; part # IH 487045 R2.
He charges $10 flat for shipping, so that's something to think about as well.
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 11-11-2014, 06:08 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I have had no luck with gates belts. Shredded them. However the belts at Tractor Supply work for me very well. Three seasons on them so far. Do what you want I'll keep doin it the way I want.
I lost track of what I own a long time ago!
