My muffler box was cracked, as a lot of them are. The correct way to fix this would be to have it tig or mig'd. I don't yet have an aluminum setup for my mig, and I didn't have the time to find a local source to tig this back together.
What I did have were some alumaweld sticks: http://www.harborfreight.com/8-piece...ods-44810.html so, I thought i'd experiment, and use them to make the box servicable. Seemed to work fine, and everything is back together. http://i85.photobucket.com/albums/k4...g?t=1376077315 There are lots of "how-to's" on using alumaweld on youtube if you search "alumaweld welding" Basically, what I found was that you need a decent size tip on your torch (I used a propane mix plumbers torch), and heat the box up until you can touch the rod to it, and it flows almost like a real weld bead would flow. Once it flows then you drag the alumaweld stick across the joint, and let it cool.
1872 W/ Kwik Way loader 1650 W/ Dual Hydraulics, and rear lift Cadplans Caddigger qa36a blower, tiller, and snow blade Gannon Earthcavator |
While I had the box all torn apart, I also fixed the cracks in the steel box, and welded the sides to strengthen it. These pics were taken before the weld were ground down/ painted.
That is why QL's will be in my "had" list of Cubs!!! Good job though...
Nice work on the repair!
I fixed mine as well. Sept it wasn't near as purdy as that
No more cubs. But never fear there will be more ![]() ![]() ![]()
Looks good.
While you have it apart, build yourself a muffler crutch, it'll help with stopping other cracking.
I fixed all my Quiet Line tractors a completly different way. I took all those part off and threw them in the scrap pile and added a strait pipe. Worked for me. Each their own though. Good job on your welding and fixes!!!
John |
Since I had to get/make complete muffler boxes. I got the AL ducts from JD 212 and adapted the changes to between the two ducts to the new tin work. I did a SW layout of the 1250 duct and tin work. Then when I got the ducts from the JD 200 series I modified the tin work drawing and had a tin man make them. I cost me $20 a complete box. And yes the tin is the correct gauge. Then I made the support bars and installed. Time will tell if this will prevent the problem. I do know one thing is the the ducts from the JD's are far more available than the ones for CC and 1/4 the cost.
If this helps
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering ![]() ![]() ![]() ![]() ![]() JD 110H:JD 112H |
| Thread Tools | |
| Display Modes | |
