Browsing Craigslist this morning, I came across someone selling a 1450 minus motor with hydraulic lift for cheap. That got me to thinking, would the Hydraulic lift from a 1450 fit and work on either a 129 or a 682? I know I'd have to swap the pump as well for the ported one in the 1450 but once I switch that, should the rest pretty much be bolt on?
-Ryan
The only thing that I can think of that would swap over is the "spool valve". The lever linkages are different. I am not sure, but the plumbing lines may not transfer over either.
I have a 1450 chassis and a running 682. I am hoping to swap rearends and other hydraulic lift components from the 1450 to the 682. This seams easier than the other way around. So far, looking at the two together, the major issue is setting up the lever and linkage to operate the spool valve. I believe with a little fabrication that this can be done.
Ryan,
The rockshafts are different from the 1450 to a "782" (that's what your 682 would then be). I also don't know if the long hyd cylinder that the 1450 used would work either. But, if you are serious...... I may know where a valve, cylinder, rockshaft, are for a 782. BUT, no rear end.... NO, none of it would fit the 129. Not easily anyway. |
-Ryan
While it is true that some of the hydraulic lift parts are different between the 1450 and a 1X9 series tractors, I don't think it would take much to make one work on the other.
I believe that the only real difference is the location of the control valve, with the valve being located on the steering column on the 1450, and on the side of the dash tower on the 1X9's this changes the plumbing and the location of the "valve handle lever". With the differences being so small and so few, it is my belief that if you mount the valve on the 1X9, on the column (just as it was on the 1450) everything else should fall into place. The cylinder, bracket, rock shaft and related parts are the same between the two.
Depending on the condition of the 1450, it may be easier to swap engines.
There are too many differences in the engines between the 129 and 1450 to make swapping feasible.
![]() Then again, I have done more unexpected things in the past
-Ryan
It would be rare to find a 129 engine that has the mounting holes for an electric pto, even if it did have, once you mounted the electric pto there would then be no place on the crank shaft for the starter pulley. Using the manual pto would also be difficult as there are no provisions on the 1450 for the pto related parts needed to engage/disengage the manual pto. After that we run into a whole different can of worms concerning the differences with the charging systems and wire looms between the two.
| Thread Tools | |
| Display Modes | |
