Old 07-29-2013, 07:33 PM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default carb won't adjust???
Hey everyone,
I've seen posts on carburetors not adjusting but couldn't find them.
I just rebuilt the carb on an original that wasn't running when I purchased it. It had been sitting for a few years. Got it ready for the first start, sediment bowl clean, checked for spark and cleaned and rebuilt the carburetor.
The tractor started with 3/4 choke and wouldn't run with any more or any less choke. I started with 1 1/2 turn out on idle and 2 turns out on main. When given the throttle it would spit and sputter.
As a test, I screwed the idle needle valve in all the way while it was running on 3/4choke and it made no change.
Any thoughts...I was thinking maybe the holes in the main needle valve didn't get completely clean.
_____________________________________________
1968 Cub Cadet 72 w/fenders, headlights, rear grote, hydraulics, creeper, rear weight box, deck and QA-42 snow thrower
Spare NF hydraulics, Brinly harrow, Brinly moldboard plow
Lots of Cub Cadets have come and gone...
Old 07-29-2013, 11:04 PM
Since the carb is back together and on the engine, I would check that first.
I always make sure ALL the holes in the carbs are very clean before putting them back together.
Is everything sealed up good? No suction leaks around mounting flange, throttle shaft not loose in bore?
Old 07-30-2013, 12:15 AM
rweaver rweaver is offline
a good way to check for leaks is spray the carb with starting fluid if it changes rpm you found a leak
Old 07-30-2013, 02:24 PM
Do you have it tight against the engine, or does it have a bad gasket? IE is it getting too much air somewhere else than through the air filter.
