I finally got a Cub, a '72 model 86. She looks pretty good and with only the regular stuff for an antique that has been sitting. I got her running and driving around. I am trying to figure out what I am missing on the front PTO so I can turn the deck on and off. From what I have been able to find the clutch assembly is there but everything that attaches to the end of the rock shaft is missing. Just a broken bolt in the end of the finger. One diagram shows a wear button attaching there, another shows the same button along with a brake shoe and disk. I am leaning towards the brake shoe and disk because of the distance between the clutch and rock shaft seems to big for just the button. However the turnbuckle between the PTO lever and rock shaft did not have any lock nuts on it so it could be way out of adjustment just from vibrating there for who knows how long. How can I determine for sure what parts I need? Any help would be appreciated.
Welcome to OCC! Congrats on your 86! Hope to see some pics of it.
Thanks. I will have to get some of those up soon.
![]() ![]() Congrats on the 86! |
![]() Quote:
http://www.ebay.com/itm/Cub-Cadet-12...#ht_2212wt_672 The difference between the 2 rockshafts is the hole for the brake shoe is recessed on the shaft, where as the hole for the wear button on a non brake shoe type rockshaft is flush with the shaft. So you want to look at the hole that broken bolt is in. Here's an example of the non brake shoe type rockshaft. http://www.ebay.com/itm/Cub-Cadet-14...item2c6dc67ea9 Hope that helps. ![]() |
![]() Quote:
Figures I would get the more expensive one. But I bet the brake lasts longer. Thanks for the quick response and the links. Pictures say a thousand words. |
I think the width is the same for the 2. If you post a pic I can tell which rockshaft you have. I have both types of rockshafts at home, and i use the brake shoe pto on my 108.
You could always switch rockshafts, depending on which style pto you want to use. As long as you can get the rockshaft bushing off so you can remove the rockshaft from the frame. |
Thread Tools | |
Display Modes | |
