Old 02-28-2013, 05:46 PM
vartz04 vartz04 is offline
Default Ring gap question
In the manual it states .010/.023 and then max as .032. My new rings when stuck in measure .017 and .023. The measurements are for a new bore which mine is not. Is it safe to say that I am good on the rings? The motor is already .030 over and it was burning oil. The only real problem I can find is that the head gasket is blown. I thought it might have been the old rings but they are almost the same when measured.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 02-28-2013, 06:46 PM
did you use the piston to insert the rings in the bore?
Up to 530 and counting...
Old 02-28-2013, 07:13 PM
Yes I was taught that is how you make it square.
Old 02-28-2013, 07:29 PM
Funny how a round thing can make it square.
Be sure your head does not have a crack in it,as I BTDT
Old 02-28-2013, 08:15 PM
@ this point it is what it is.
Since you have the new rings, put them in,
and hope it slows up the oil usage.
Unless it is using enough oil to foul plugs or breaking your budget on oil purchases, enjoy it.
A little smoke never hurt anything.
If you are fond of the block, it can be sleeved back to std. but it does cost a bit.$$$$
