OK one problem after another my 125 is just not acting right first the PTO clutch then the charging system now I was out the other night blowing snow and it just died got off it was out of gas no big deal. So I thought 20 min later dies again this time I had to jump it. 15-20 min later dies again so I jump it once again Finnish blowing and park it tell I could take a look.so today I go out thinking its my sentiment bowl its clean I proceed to take the bowl of the carb once again clean. So at that point I'm like what the hell I took the carb apart cleaned the jets got it all back together mind you while I'm doing that I have my battery on a charger so I get that back on starts right up running a lot better to lol. But 20 min it to it running it dies so I start taking all the electrical apart and brushing all contacts and adding dialetric grease were need be. Get it all back together and the battery is dead I put a battery out of my wheel horse in there starts right up ran for 5 min and dies. Here is the kicker if I turn it off it starts back up if I let it die it kills the battery. It has never done this before. I have nothing extra hooked up to it either no lights nothing. PLEASE HELP SAVE MY CUB CADET BEFORE I TAKE MY AGGRESSION OUT ON IT WITH LARGE CALIBOR WEPONS AND STICK TO MY WHEEL HORSE.
1968 cub cadet 125 Ih Snowblower Ih Dozer blade Ih Rear rototiller Ih 48" deck Winter cab |
It sounds like you have a short some where in the wiring.
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
My 102-D did that a few years ago and it turned out to be a failing V/R.
Switched it with another I had and no problems since!
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
Is there a way to test the V/R ? Or is easier to just replace it.
Could be the coil going dead after it warms up. Mike
![]() Quote:
The Chassis Service Manual for your tractor, part of the 1x4/5 Series, on page 1-30, states, "The contact points of a regulator will not operate indefinitely without some attention. A majority of regulator troubles can be eliminated by a simple cleaning of the contact points and slight adjustments." The Technical Library for Tractors on this site includes a link to the manual; http://ccmanuals.info/pdf/1x4-5%20Service%20Manual.pdf The Service Manual called out above has instructions for cleaning and adjusting the voltage regulator, and I think other instructional sources can be found on the web. I downloaded the attached picture from somewhere, but forgot to note from whence it came. I think it would be worth your while to open it up and check to see that none of the contacts are welded shut. If you decide to replace it, be sure to identify all the terminals on both the old and the new part and match them up correctly. Roland Bedell has noted the P/N of both the original and replacement regulators for IH CC tractors in the Technical Library for Tractors on this site, and has included diagrams of each part as well as terminal legends --very helpful! (see http://www.onlycubcadets.net/forum/showthread.php?t=2) Finally, Paul Funk has and interesting write-up on how he thinks a mechanical voltage regulator works which can be found in the How-To section of his CubCadetMan web site: http://www.cubcadetman.com/content/i...tor-&Itemid=53 |
Thank you for that advice I will check that out first I appreciate it.
Thread Tools | |
Display Modes | |
