Old 01-25-2013, 07:31 PM
ramman16248 ramman16248 is offline
Default Can you help me ID this cub?
A guy wants to trade me this Cub for a go cart I have. I am going to do it, I know him and he said the tractor ran until he got a gas leak in the tank. That isn't an issue. What is is the tractor is labeled a 147 yet it has a stick transmission. Were there 147's built with 3 speeds? If not can you help me ID it by the photo? (I don't have access to the serial # yet, but will in a few days). Thanks, Jason
cub147 by ramman16248, on Flickr
Old 01-25-2013, 07:36 PM
It looks like a frankencub! The frame suggests it's a 147 due to the cut outs where the engine flywheel is (and larger 14HP flywheel engine) and I'm guessing a PO (previous owner) had a problem at one time with they hydro transmission and put in a gear drive.
Old 01-25-2013, 07:37 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Its hard to tell, but I would say it is a 1x6 series... either a 106 or 126 depending on the size of the engine. Looks like someone swapped the decals/hood & dash at some point. And no 147 were strictly hydrostatics.
- Cory Sanderson
Old 01-25-2013, 07:39 PM
Muzzy Muzzy is offline
It has a 147 frame from what I can see but, the standard is'nt right. Looks like half 126 half 147.
Old 01-25-2013, 07:45 PM
Ok, So hypothetically, if someone did change the rear end out, it "SHOULD" work the same as far as mower etc goes. Just the clutch and rear is swapped possibly?
Old 01-25-2013, 07:46 PM
Does the dash have a hole in it for a hydro shaft?
Old 01-25-2013, 07:47 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
That is a 147 since it has the notched frame and correct hoods and fenders. I agree with drglinski looks like someone just put a gear drive tranny in it.
Old 01-25-2013, 07:53 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
the fender pan doesnt look correct for it.
Doug
Original , 100 , 125 , 582
Old 01-25-2013, 07:59 PM
The fender pan looks just like the one on my 147.
Old 01-25-2013, 08:00 PM
cub123's Avatar
cub123 cub123 is offline
It's a 147 someone has put a three speed in, the electric lift has also been replaced with a manual lift. A gear drive 14 hp NF sounds cool
