Old 04-25-2012, 09:58 PM
tonebone tonebone is offline
Default 2160 cutting problems
i have a 2160 with a 48 inch deck, it began leaving cut grass and leaves behind the deck between the left and center blade,switched blades around with no change. Replaced with new high lift blades with no change. I did notice that the distance between the tips of the center blade and right blade is close...and the distance between the center blade tip and left blade tip is twice the distance. Only thing I can notice..and the only thing that I cant change or fix. Any suggestions on this problem??? thanks in advance...Tonebone
Old 04-26-2012, 07:42 AM
Are all 3 blades the same length? Cub parts site calls for 15.94" length for all 3. Maybe a baffle is missing? A pic of the underside would help.
Old 04-26-2012, 08:03 AM
When I found the blade gap to be different, I found one of the spindles was sitting at an angle due to the deck being bent.
I had probably hit something.
With the deck off, I just grabbed the blade and straightened the deck/spindle.
If you can't bend the deck back, invite your BIG friend over for burgers!!
I had actually bent the deck enough that the blades were hitting.
Old 05-03-2012, 09:48 PM
thanks for the responses, i'll have to take the deck off and measure all 3 blades to ensure their equal length. If they are all the same length, I'll have to check for a spindle /deck being bent. I'll post back when i can get around to this...thanks again for the responses.
