Old 12-11-2011, 12:27 AM
bogey68's Avatar
bogey68 bogey68 is offline
Default A little carbon
After 12 years of snow plowing, grooming my gravel drive. My 129 is sick. rebuilt the carb. (# 26 carter) Removed the head to find shes .30 over. and full of carbon. Cleaned her up nice lapped the head flat. Installed the new head gasket. Started her up and tweeked the carb in ( I think) ran her and when i shut her down she ran on sputtering and gasping for life. Too Much gas ?? Im not sure what she needs???
Old 12-11-2011, 07:15 PM
guido guido is offline
Sounds like you have a "hot spot" igniting the fuel after the ignition is turned off. Might be a bit of carbon let on the head?
Regards, Guido
Old 12-11-2011, 08:22 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default run-on
Do you have ~2 turns out on the mixture screws? You can count carefully and return the adjustment to where it is without messing things up too much. If it's 1.5 or 2.5 it's probably not the problem. If it's 4 or 5 it might be.
Guido's comment is a good one. Did it do this ONCE, or does it do it all the time now?
Did you mess with the timing or points at all??
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-11-2011, 09:14 PM
Once you get the carbon off, flatten your head, check your points and reset the timing and see if that cures it.
