Is there away to lock out the float when using a Haban front blade on a Cyclops super like a 2084 or 2086? I want some downforce to do some light grading.
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
Never mind, I see by the search on the forum locking out the float on a front blade is not recommended.
On my manual lift tractors I can apply pressure down holding the lift arm, apply pressure.
Don't know if you can do so with the hydro. Perhaps add weights to the plow / dozer blade? You did say light grading. My long gravel drives need grading and rolling and I also use a plate tamper. ![]() https://youtu.be/lalmNq3d-KI
Tankman '95 CCC 1641 Eastern PA USMC |
If you need light down pressure, your best bet it to add a small amount of weight to the blade itself as tankman said. Otherwise, like you've read, using the lift rod to apply down pressure will result in a bent lift rod; ask me how I know
-Ryan
Thread Tools | |
Display Modes | |
