Hello I'm new to this forum and new to cub cadets ..I got two cub cadets from a good buddy of mine . One needs a carb and a mower deck .. so if u have one let me know . And the second one will run for about an hour or so then lose pressure and like sputter out .. they are club cadet 100's I believe 77?? If that sound right .. I live in Toledo Ohio .. thanks
Welcome to OCC! Glad to have you! If you have 100's, they were made between 63-65. Also, if you're looking for a mower deck, please post a wanted ad, in the Wanted Items section of the site.
Oh nope I was just hoping someone knew why it would shut down
I believe I have heard others mention these symptoms before, if I remember correctly they stated the problem was most likely a bad condensor, or it could be a bad coil.
Keep your pants on, someone will chime in soon enough with some insight to your problem (some folks have to work you know....LOL)! Oh, and by the way welcome to the site, you will find alot of useful material on here, check out the manuals section, you should be able to download a manual for your tractor, and the kohler engine...they are great for looking up how to maintain and repair you cub!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
![]() ![]() Sounds like a coil but a hour is a long time for it to shut off. You can try the coil from the other 100 and see if that helps it. ![]() Follow Allen's advice and place a want ad in the wanted section of the site and you'll have alot better results. |
Is the fuel tank vented? Try and loosen the cap and see if that helps.
I'll have to try the tank vent .. do u think that marvel mistory oil would help? Yeah I'm going to try the other coil .. hope it works I'm so pumped .. I will post a pic once I get it all washed and dirt free ...
And i work full time ![]() And would u re paint it or clean and wax it up ? |
Try a new condenser also. Make sure the points are clean and fresh. Some light sandpaper can clean them up. They could have some buildup.
![]() ![]() We don't need them all polished up to see them, everyone appreciates a hard working cub!!! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Okay I checked my wires nothing . I changed and cleaned the coil . And when I shut it off I noticed a gurgling sound .. come to find out the gas in tank is boiling .. it has a non stock muffler on it .. would that cause it to boil the gas ?
Tags |
cub 100 |
Thread Tools | |
Display Modes | |
