Old 07-16-2025, 07:50 AM
DSarow DSarow is offline
I have a K-301 which is 12hp.It doesn't even have the proper machining to have balance gears,so it's probably not that.My cub rattles,30 hours on overhaul.Nature of the beast,I'm not at all worried.
But if my Kawasaki sounds like that,I think I have a problem
Old 07-26-2025, 08:07 PM
I-H73's Avatar
I-H73 I-H73 is offline
As small as it is, I'd guess gov gear.
No balance gears in a small kohler.
You can try snaking a borescope in the drain plug opening,
if more break off, you will have a big window in the block to look into.
The monkeys with hammers showed up & they don't play a good tune.
Old 07-26-2025, 08:12 PM
And you didn't notice that right away in the first place??!!
Old 07-26-2025, 09:30 PM
Now you get to take it apart for a post-mortem and see exactly
what went amiss instead of guessing.
Ken
Old 07-27-2025, 09:10 AM
green407's Avatar
green407 green407 is offline
Gazing into my Chrystal ball. I see a dentist in your future to replace the missing tooth with a full set of teeth on that gear.
I also suggest you purchase a lottery ticket because your luck of averting
a disaster was great.
I also see internal engine surgery in the near future.
Hope you didn't buy a lottery ticket.
Guess a postmortem it is.
128 X 2, 129, 149, 1250, 1450 x 2
