Old 01-09-2024, 07:34 AM
zilla24's Avatar
zilla24 zilla24 is offline
When I was an apprentice the shop I was working in occasionally did some casting work. A senior machinist had to drill and tap some NPT holes at 45 degrees, his setup had the head kicked over and the mass of the casting slightly off center on the machine table, as he wheeled it to right in "x" to check clearances the machine tipped over and fell on its face. Wish I had a picture of that one! Thankfully nobody was hurt, it happened in the blink of an eye. While it was an extreme for the machine and by all rights outside of the capacity I've always thought it is good insurance and have been pro-anchor bolts from that point on!
CC Tractors: 1650, 1200, 800, 149, 86, 782D, 2072
Gone but not forgotten: 1450, 1250, 1000, 125, 1572, 782D, Original
Old 01-09-2024, 07:57 AM
Ok,
I stand EDUCATED!
One is never too old to learn!
I removed my post so as not to advise someone into doing an unsafe act.
Old 01-09-2024, 08:47 AM
zilla24's Avatar
Cheers friend!
Ok,
I stand EDUCATED!
Old 02-18-2024, 10:10 AM
IHinIN IHinIN is offline
Got the mill running a few weeks ago. I used a 5hp VFD to get 3-phase power. It is housed inside a Fat 50 cal ammo can on the back of the mill base. The original drum switch is wired into the inputs of the drive to control Fwd, Rev and stop. The head was a little noisy which turned out to be a worn key and bushings in the variable speed motor pulley. I epoxied new plastic bushings into the pulley and made a new bronze key. Now, the mill is much quieter.
Old 08-18-2024, 08:55 AM
Changed up the wiring on the mill. I added a line reactor before the VFD to hopefully eliminate faults caused by voltage spikes from the incoming power. There was a digital readout on the quill that didn’t work, so I put on a new one. I also tightened up the gibs and the lead screw backlash.
Old 02-14-2026, 09:47 AM
I recently added a power feed unit to the knee. It is much nicer raising and lowering the table now.
Old 02-18-2026, 08:45 PM
Farmall450's Avatar
What have you been machining lately?
I still haven't needed the mill, I do need the lathe about twice a year for some sort of project or another
Old 02-19-2026, 09:07 PM
I’ve mostly been using the mill to make tools. My biggest project was building a cutter grinder to sharpen endmills. I recently built a 24” brake for my shop press.
Old 02-19-2026, 09:25 PM
Ambush Ambush is offline
That’s some impressive work!!
