hi, it's been a while since have made any progress on my Cub. Lots of other stuff keeps coming up including a lot of supporting my wife's efforts. Anyway, I'm going to try and pick up where I left off and continue to rebuild the engine (Hopefully have it ready for the spring). Tonight I worked on the flywheel drive cup, which I damaged when I removed it from the crank shaft end back in February. I used a low temp aluminum brazing rod and my propane torch to try my hand at the fix. I think it turned out OK, had to really heat the cup up a lot before the rod would melt in and bond.
