Originally Posted by ironman
I respectively need someone to explain to me how that happens.
In my way of learning, the coil of the PTO is an electromagnet that gets energized when 12 volts and ground are applied to it's windings.
The resistance of the coil windings is fixed and never changes, therefore the current going through it has to remain constant. current = voltage divided by resistance. (I=E/R).
So how does changing the air gap of a passive part in the game cause more current to flow thru the coil, whether it is a thousandth of an inch or a thousand miles. I'm probably wrong but I need it explained to me.
My money is on the windings shorting out, thereby lowering the coil resistance, thus sucking more current and heating the fuse and wire.
I agree with this completely. I was wondering the same thing.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
