Originally Posted by DieselDoctor
That's coming along very nicely. If you do decide to mount a pump off the rear for the dump bed, be sure to have enough capacity in your hydraulic reservoir to help cool the oil. Having the pump turning constantly will create some added heat. Keep the pictures coming!
While that is a good point, that pump is smaller than the charge pump on the hydro, which runs all the time.
Another note about using a ported pump is the hydro's do help cool the oil. Whether using a seperate pump, or a hydro, one or both rears can still be sued as a reservoir.
