Lets assum that all the oil was gone even before all these issues. That means it left the engine while running around the yard cutting the grass, and over a period of maybe as much as a year. that alone indicates to me a defective engine, but i'd also have seen big drips in shed or on pavement if that was the case.
said before. let me add this... if engine failed during a 15 min run now, why didnt it fail last time i cut grass for an hour?
sorta hints oil left after grass cut and before this last deadly run...
pros n cons of changing break in oil... not changing the oil for 20 hours would never explain why there was NO oil in crankcase, per service tech...
thanx for feedbact. st
ps, finding kohler knows issue caused by case bolts working loose, losing oil, yet hasnt fixed it yer, afaik.
