Originally Posted by cooperino
Eliminate possibility of deck issue by removing belt. Then run the unit. If it still does stall after 20 min I would bet money on fuel or air delivery issue. Have you changed fuel and air filters recently?
I wouldn't do that quite yet. If you were to run it with the pto/deck off chances are it will take longer or may not die at all ( if its a fuel issue). Possibly hiding the issue. I would rebuild/clean the carb, clean and flush the fuel tank. Try that
