All of the PTO's I've taken off have a set screw with a nut tightened on the concentrec collar that had to be removed before I could loosen the ring (clockways if I remember correctly). Ive had stuck stripped screws before, I just picked up a good set of cobalt drills and drilled it out. The key is slow speed, and lots of oil to keep the drill cool. I used thread cutting oil from the plumbing department of local hardware store. I took my time and didnt rush it and had it off in no time.
I did have to use a lenght of hard wood applied to back side of the pto to get it to seperate from the bearing. In the end the only danage was to the set screw that I pulled out using an easy out. one of the few times an easy out actually worked.
