switch
The ignition switch itself is responsible for providing the voltage from the battery to BOTH the starter solenoid AND the black wire to the + side of the coil while in the cranking position. You can test this with a voltmeter but that's the way its designed to work
+12 needs to be at the coil during the run position, and in the crank position. It's removed of course when the key is in the off position.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102 parts
It's only original ONCE!
