I also have a 1450 with a Johnson loader on it. When I got it, it was also run off the ported pump. I added a separate hydraulic pump, ( and power steering) the ported pump just does not have enough power for the loader for what you want to do. After changing mine to a dedicated pump it made a world of difference. Here is the pump I used https://www.northerntool.com/shop/to...9708_200329708
If you are going to run it off a pulley, make sure the pump is rated for a side load. I ran mine off the front PTO. Hope this helps
72,147,149,169,1450w/Johnson loader,#2 cart, IH lawn sweeper
