thanks for the info, I found the bolts are 9/16 for the engine mount, i did have move the cover that mounts to engine under the electric to have enough room to slide it forward.
thanks for the link, i was able to get a similar belt at the napa. It appears the lift pump came with the correct rockshaft arm. I got the pump installed, hopefully today I can get everything tightened down thanks again
