Heads are the same as far as fit. They are interchangeable. Might need a longer spark plug wire, and be sure to use the engine tin for the head that fits the head. (Spark plug hole drilled in right spot.) Check the bolts also. Some heads have recessed holes and need a bushing, some need longer bolts, ect. Pretty straight forward.
