Originally Posted by CC1572
This is the area of the leak. I believe this is the same rearend you were talking about. It's been ages since I've researched this mower. But just by removing thoes 2 bolts on either side of the shaft I can replace the seals and bearings if needed correct? Are they a press fit then I assume?
Yes that is the charge pump held on with 2 bolts.
You will notice one of the ears
where the bolts go through, on the right side, has a flat milled on it.
Make sure you put it back the same way or your lawnmower will not move.
There is an "O" ring seal between the charge pump to the hydro, replace it so it don't start leaking.
You can replace just the outer seal if there is no play in the shaft.
It will come out if you put a screw in the seal between the lip and outside diameter and pull it out with pliers or suitable pry tool,
and reinstall a new one.
Or if it is stuck, you can remove the charge pump and pick it out.
IIRR the "bearing" is a needle type, not ball.
but they usually do not give trouble.
Now load and read the service manual As Sam suggested
