Little 982 help?
My implement lift isn't lifting my 442 3 point tiller. Historically, after a bit of use it would get slow, but now it will only lift an inch or so and that's it. I've read some threads and checked for issues within the 'lift line', but doesn't look like any broke welds or roll pins. I can stand on the 3 pt lift arms and it lifts me easily. I went thru my service manual and it refers to pressure testing/shimming the implement lift valve, but the service manual refers to the 'specs' for the info on shimming, which I don't seem to have? There is less than 10 hours on the hydro fluid, and the tractor has no issues moving forward or reverse. I took the center cover off and watched the cylinder move thru it's entire motion with no weight on the lift, but when the tiller is hooked up I can see the cylinder stall. No leaks either. Thanks!
Original Member #54
