I guess I just don't know how to navigate this manual then. I've read pages 3-36 through 3-49 multiple times and couldn't find anything about removing the rearend. Either way I had some time this morning after work to dig into it and it was 4 bolts hydro lines and it slid out without the rearend removal. But now I'm faced with another possible problem. The pump I got from Ray is different then the one I pulled off. If it won't work no problem I'm sure Ray will fix the issue. Other then the obvious forward reverse control, the original pump has some pins and a oil gallery around the mating surface with the rearend. The new replacement pump does not have either pins or gallery. Original on the left. Replacement on the right.
