I set the tractor on 6x6 wood blocks or any other similar
support,----- (of course taking common sense safety precaution) and go about leveling a deck.
Easy to take measurements and make adjustments that way.
As far as the front roller, most I've seen are quite a bit above the surface of the lawn.
I always figured they are to help in an incline situation, or loading operation.
Way to high to be of help anti- scalping.
As far as the wheel adjustment, I run them just off the surface,allowing the deck to hang on the mule drive.
I do not measure from any deck edges, but from the blade cutting tips both front to rear and then from side to side.
