View Single Post
Old 08-10-2018, 12:12 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Now when you are working on removing/replacing the coiled or spiral pin,
it is recommended that you support the coupling with a jack or other suitable
device so as to minimize the stress on the shaft bearing.
It is not good to pound on a pin punch with a shaft unsupported.
And do use the mentioned pin, not a bolt or common roll pin.
Or you use a clamp to act as a press. I hadda improvise with mine. It's a PIA, but it got the job done.
Plow blade
#2 Cart
QA36 snowthower
