Now when you are working on removing/replacing the coiled or spiral pin,
it is recommended that you support the coupling with a jack or other suitable
device so as to minimize the stress on the shaft bearing.
It is not good to pound on a pin punch with a shaft unsupported.
And do use the mentioned pin, not a bolt or common roll pin.
