Originally Posted by darkminion_17
What a dirty motor!
Is this gas tank the type with the foam in it to keep the gas from sloshing around?
If you removed it then that may be an issue.
The motor isn't nearly as dirty as the carb - most of what you see on the motor is dust it collected when I was last trying to vacuum up leaves as it had been hosed off prior. As for the foam question, as far as I know, no, there was no foam in it. If there was, the previous owner removed it - not I.
