Originally Posted by farmall fred
On the cast iron rear issue I was only trying to add some weight and use parts that I already have here without having to spend extra money. It seemed to be a easy to add about 60 lbs to the rear. I guess the easiest way to go is put my SGT pump output shaft and reduction gear in my Cyclops rear and add a set of braces. If I do this I could sell the cast rear and recoup some of my cost. Thanks for your input and advice it is appreciated.
Tom
When I did my cast rear, I picked up a cast rear from a 12xx or 14xx I believe. Swapped the internals/axles/hydro pump from the 1872 rear in to the cast one. No need to bore the axle tubes since the axle diameter is the same at the bearing surface. Pretty easy swap as long as you keep all the SGT internals together. Setting backlash, ect. was the hardest part.
