Body fill
Despite my better judgement I’ll chime in to this controversial subject: similar to painting a Cub Cadet - Green. What you can do is 2-4 coats of high build primer and / or a skim coat of 3M Premium Glaze or “Body Fill” also EverCoat Rage Ultra is some good quality filler. Do not buy USC or Bondo brands as they are a nightmare to sand. Spend a little extra, a quart will be more than enough. Start with 80 grit then work up to 320 or higher to avoid sand scratches showing in the final paint. It’s not for the average re-paint but if you want the best quality then you have to do what no one else does.
