05-05-2019, 03:19 AM
Originally Posted by nitsuj
I know this is an old thread, but its full of good info, so I figured I'd ask my question here so anymore info would stay in one place.
So I performed the relay installation. Worked well, no more clicks when I hit the starter. But I'm having a weird side effect. The starter now engages at the first key position. As in, normally, you click to position one, dash light illuminate, then position 2, a momentary position that spins the starter until the tractor fires up. Well, now my starter starts spinning on position 1. Turn the key one click and the starter spins. If you go past position one, and then come back, it stops. I'm not sure why this is, or how the relay installation could have caused it. Any advice would be welcome.
Double check the wiring according to the link in post #3. Be sure you have correctly identified the terminals on the relay. I had to take mine out in the sun to to tell #85 from #86.
Cannon
