View Single Post
Old 09-23-2020, 10:59 PM
Farmall450's Avatar
Ordered some $2 motor mounts from NAPA that should take a bit of vibration out. Might cut them in half to stop the engine from raising too much. Just got the muffler on, and will test fit the grill/hood with the engine's front mounts in the rearmost OEM bolt holes. Will have to mark and drill 2 more holes + oil drain egress.
Muffler is going to take some considerable re routing to get out the front left, let alone right like OEM.
Stay tuned.
