Originally Posted by Sergeant
That's what I Thought, But I was confused By Roland Giving him the Part Number for the straight IH 3 Point Bar, I gave him the Part Number for the True MTD Cat 0 3 point Hitch Lift Bar.
I bet Aaron from Xtreme would Give Him the dimensions for the Bar if He wants to Make it himself because Aaron's Bar is based On the OEM Cat 0 Lift Bar Not the IH 3 Point Lift Bar basically if anybody has a standard Garden tractor with the MTD Made Cat 0 they could give him the dimensions as well for the Hydraulic Lift Models used Bar 703-0811
It's public info when the repros are just the IH/CCC design.
