If you need to choke it, it's lean. Sounds like it sucked dirt into the carb when it ran out of fuel. I think another thorough carb cleaning is in order before tearing into the fuel pump, especially if you already checked and has good flow. I remember reading here that those vanguards are set lean from the factory because of emissions, doesn't take much to cause a problem.
Bill
