View Single Post
Old 01-09-2021, 10:10 PM
Ambush Ambush is online now
Default Loader Build For The 149
I can't run the tractor right now because I'm still waiting on some drive shaft parts, and I'm catching up to some of the other repairs. Sooo, might as well start building the FEL.
The planning has be churning around in my head for a few months and the details are starting to emerge to the point that I can start cutting metal with conviction. I've started with the under frame member and the two mast posts.
Both the 4X4" under tube and the two 2X4"mast tubes will be reservoir, giving me about four gallons plus what's in the system. The tubes will incorporate baffles to control flow for cooling and aeration. Next is building the tube to tractor frame brackets.
