Originally Posted by sawdustdad
That's exactly what I have, a bearing in a two bolt housing that allows for some shaft misalignment. Was thinking about drilling and tapping the boss on the back of the forward axle, then shimming the pillow block bearing as needed. Only down side is I need to disconnect the shaft at the forward hydro to put a new belt on, so that's one more thing to deal with.
I am using a pillow block as well. I wanted to bolt it to the top of the front hydro but the pillow block was a little to tall. I'm using a heavy cast one that is self aligning. I ended up just bolting it to a piece of angle and welding the angle to the frame. I am only planning on using a single belt so I am concerned about that now. Have you sorted out why the belt shred happened? The issue with the rear hydro did you find out why it wasn't driving? (maybe I missed something in the posts)
