Did you use the correct hydro filter and fluid?
Suggest checking the hydro linkage from lever to springs under the frame closure plate between the fender pan and dash tower. Look at every joint connection for wear/looseness and particularly the spring area at the hydro.
Post pictures if any questionable areas.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
