Steering play
I was wanting to fix the steering play on my 2155. Ive seen videos of people replacing the bearing at the bottom of the steering column above the gear but it doesn’t appear the 2000 series has that? All I can see on the parts diagram is a bearing at the top of the column, under the steering wheel, the only thing around the gear at the bottom are washers and the nut. Would the bearing at the top of the column be the culprit, or does anyone have any experience with steering play on these 2000 series models?
