Originally Posted by Gary C
The "Rinky dink" weedeater 1 rider I bought used a few years back had that option incorporated in the ignition switch, there was a position you could turn the key to , where the deck didn't turn off when backing up.
New Cubs have had the reverse caution feature for that since at least the LT/GT series. Unfortunately the older ones did not yet have that loophole, but they made the sensor very easy to access/unplug
